Guth
As I don't see too much mention of this speaker around here, or on the web in general, I thought I'd go ahead and create a post dedicated to the Snell Type M if for no other reason than to help develop awareness of this little speaker. I was inspired to do so when once again I recently found myself so immersed in the music that I lost track of what I was doing. This is not an uncommon occurrence with these speakers. While they are definitely fun to listen to, they aren't over the top. These little speakers reproduce music with such depth and 3-dimensionality that it simply catches me by surprise again and again.
I have the Type M's set up in my home office where they've replaced a set of ADS L300W's that I had been using up until I acquired the Type M's earlier this year. I am powering them with a NAD D3020 Hybrid Digital Integrated Amplifier (rated at 30 wpc into 8Ω). I'm also using a small JL Audio Dominion d108 subwoofer, which I'll admit enhances the overall listening experience significantly. I will say that as much as I enjoyed the small ADS speakers, they never quite managed to grab me the same way that the Snell Type M's have. I listen to this system on a near-daily basis and it has brought me far more joy than I could have ever imagined.
I haven't been able to locate a whole lot of information on the Type M's so I have no idea when they were produced, although I do know that they came along after Peter Snell's involvement with the company's designs. These would appear to be of similar age as the Snell Type K/II speakers that I own. Like the Type K/II, the Type M is a sealed design. At 7.5" wide x 11" tall x 6" deep (including the grills), these are a bit bigger than the ADS L300W speakers that I had been using. The pair that I have is finished in real wood veneer — black Ash in this case. While the quality of construction is very nice, the looks really aren't anything to write home about. (Especially when compared to the gorgeous ADS300W that they replaced.) Therefore these speakers tend to disappear both visually as well as sonically, which is their real calling card. The driver array consists of a 1" soft dome tweeter that includes a fine wire mesh grill along with what appears to be a 5" polypropylene woofer that uses a rubber surround. I've seen these rated at 8Ω but have not confirmed this. I've just happily been letting them do their thing.
I have my pair set up in a nearfield configuration in my small space. They are sitting upon a shelf on the wall in front of me that places the tweeters above ear level. I am using some Auralex foam speaker supports that angles the speakers downward slightly. The two speakers are located 3' apart and sit 3' away from my ears. I have the 8" JL Audio Dominion subwoofer placed underneath my desk and once I got the integration of this subwoofer dialed in, it's been "out of sight, out of mind". The effect is almost eerie in its ability to convincingly portray the Type M's themselves as having full, tight, articulate bass. Overall there is a lot of depth to the music coming from the little Snell's. That music is well defined without being sterile or fatiguing. I think the key to this system revolves around the subwoofers ability to crossover at such a high frequency as well as it being placed underneath my desk. This seems to help not only with the visual illusion that no subwoofer is involved, but also with the sonic illusion as well. I can't claim to know why this is. I'm just very happy with the results.
While these speakers are getting on in years now, should you ever happen upon a pair of the Snell Type M's, I would recommend that you give them a listen.
