skyegreen424
brandon
Hi!!
I posted in another thread to gauge interest in logging the recap of a late 80s Technics SA-R477 100wpc unit.
Here's the thread because I made a parts list, checked it twice, and ordered it all on Digikey for delivery in about three days.
I've got a healthy mix of electrolytic capacitors and polypropylenes. There's about 20 3.3uF capacitors all through the receiver and all of those will be "upgraded" to polypropylenes.
Anyways, here's what I've done so far:
I cleaned the potentiometers.
I also replaced the relay. This was a more involved repair than cleaning the pots but it needed to happen. Last year I tried cleaning the original relay myself but in the process destroyed it. A year later with a years worth of learning and hindsight and I would have and should have just put a new relay in. I've got a new clear Omron relay installed and it looks awesome. I made a TikTok of the process if anyone wants to check it out -- https://www.tiktok.com/@dead__fi/video/7122649932762467630?_t=8ULP2SdW3Xm&_r=1
Also, I'd like to say that this is a super easy unit to work on!! It's got a lot of parts sure but there's a lot of the same cap PLUS you can take the entire boards out easily. Maybe I just haven't worked on nicer units before but this is so much more convenient than constantly turning the entire unit to get one cap out. Good stuff, Panasonic!
I'll attach some pictures I've taken of my process so far. I gotta get more into the habit of doing this, cus I go to an art school which is all about documenting your practices/steps to completion, haha.
Anyways, I've got a few questions.
1) Why did they use such tiny capacitors when the boards support and even seem to be designed for the larger/more normally sized equivalents? Is there some kind of performance benefit or is this to decrease the cost?
2) I'm aware this unit runs hot even though it's got a fan in it. Does putting in an always running fan actually help this series of units? I've seen a couple tutorials for how to add in a constant fan plus its controller but if anyone knows any good tutorials for how to install a better fan let me know :-D
3) Should I replace the thermal grease currently on the transistors with something better like computer thermal paste (I have arctic mx4 which I believe is not conductive)
4) Any best practices for recapping besides using a dim bulb tester and testing the unit constantly that I should be aware of?
Thanks guys!!! Hope this log is helpful somewhat to somebody. There are many great amplifiers from this time period which are approaching the age where a recap as a preventative thing will allow its use for many more years... that's the big reason why I'm in deep on this one ;_)
