Pabloaguas
Hi Everyone,
I have found this forum to be very helpful for my ametuer tube amp musings. Much thanks.
Can anyone help me with OPT calculations? There must be an equation for this somewhere, but I can't seem to find it.
I'm trying to calculate the primary impedance and how it varies based on the speaker impedance. My speakers are 6-ohm Audio Note "K". So for most applications with 6-ohm speakers, there is no 6-ohm tap, and therefore I would choose either the 8-ohm or 4-ohm secondary. So wondering how to calculate the variation on how this affects the primary winding.
For example, if I were to purchase a Hashimoto HC-507U or H-207U, and use the 5k primary tap, and hooked my 6-ohm speaker to the 8-ohm tap, then what would the primary impedance actually be? Same as if I use the 4-ohm tap with my 6-ohm speaker, what would the primary be? And if I use the 7k primary and 8-ohm tap with 6-ohm speaker, what would the primary impedance be?
Maybe Peter Q will chime in- I believe that he recommends to just use the 8-ohm tap for his speakers across all applications. However, with my current transformers, which are clearly not the right ones for SE KT88 because they are only 2.6k (Audio Note T-150), the 4-ohm tap sounds better because it would seem to raise the primary impedance when tapped with 6-ohm speakers. Am I thinking this correctly?
So- if someone can provide an equation of this it would be much appreciated!
Or, just the following 3 calculations would be appreciated:
A. 5k primary, 8-ohm tap secondary with 6-ohm speaker
B. 5k primary, 4-ohm tap secondary with 6-ohm speaker
C. 7k primary, 8-ohm tap secondary with 6-ohm speaker
(For this application, I'm looking at using either of the abovementioned Hasimoto transformers in UL mode, and my output tube is GEC KT88 equivalent with cathode bias and some global negative feedback, so thinking I want to be somewhere in the 5k-6k range for the primary of my OPT)
Thanks everyone
BTW, will be selling a used pair of AN T150 OPTs after making the switch to something more appropriate for the KT88
Thanks everyone
