The Unloved: Sony TA-AX401
MFRD
AK Subscriber
Some months back I spotted a small stack of audio components out by the curb on trash day. Not wanting them to end up in a landfill, i stopped to rescue them. There were an Onkyo TX-8211 receiver, a MCS 3873 amp, and the titular Sony.
When I quick-tested them, the Onkyo worked just fine - in fact it's been on bench duty since my little Yamaha took ill - but the MCS and the Sony were stuck in protection so they went on a shelf.
But last weekend I brought home a massive pair of JBL 15" speakers whose electrical health is highly suspect. I needed an expandable amp with which to test them, so I thought I'd take a more in-depth look at these two.
The MCS had 3 blown outputs and repairing it makes no economical sense, so after getting some good advice in this thread I started an organ-donor pile in my garage with the MCS as founding member.
Which leaves the Sony. Here she is; she sure is filthy.
But I'm not going to clean it or spend any time on it until it's been diagnosed and I know I'm going to repair it - because if I don't repair it, cleaning it is just a waste of time.
The inside doesn't look quite as gross, but there's plenty of dust
It's a pretty clean layout; most functions are handled by ICs. The Sanken outputs are so large I first thought they were some kind of STK. Stated power is 135wpc RMS both channels driven at "no more than .9% THD" - not exactly a specs queen, this one :)
A very clean scan of the service manual is available on Elektrotanya. The set of schematics is outstanding, probably the best I've seen.
The foil side of the PCB is extremely well labeled, sections are delineated, pinouts are marked. All in all, this humble amp is just a joy to work on, and maybe just because of that I'm determined to save it.
On power up, everything looks normal but the speaker relay doesn't close. There's 0V at the coil, so the protection circuit must be seeing something it doesn't like. There's no DC at the relay input, however.
After warm-up nothing looks out of the ordinary. Everything is quiet. No suspect smells. The thermal camera reveals no overheating.
Soon enough it appears that B- is -65V as per schematic, but B+ is only 43V. While checking power supply voltages it appears that touching the negative pin of C801 the B+ filter cap with my DMM probe causes the speaker relay to close!
Which, on closer look, kind of makes sense:
I didn't write it down but I think there was 35 kilohms between cap pin and solder pad when I measured it later.
I reflowed all four joints and turned the amp back on, and sure enough the relay closed!
I was sure I nailed it, but when I connected sacrificial speakers and a signal generator and turned up the volume, there was no sound.
B+ and B- were both in spec, however; so that was encouraging.
I traced the signal with a scope and it disappeared at IC501 and IC601, the VAS ICs if I'm not mistaken? They're NEC uPC1342 so I downloaded a datasheet and started probing at the pins
Turns out 65V was present at pins 1 and 2, but at pins 9 and 10 there was 150mV instead of -65V, and that could cause issues.
Backtracking on the B- rail, there was 0V everywhere until I got to R537, a fusible resistor and therefore an excellent potential culprit. And while there was 0V downstream there was a healthy 65V upstream!
I didn't have that type resistor on hand, so I figured I'd jumper the blown one with my DMM set to current mode, ready to yank it if the current was too high, but as it turns out the current seemed perfectly normal at 60mA.
But... still no sound out of the speakers, with the selector on A+B. So I started pushing all the switches and twiddling all the knobs, as one does when one is frustrated and has no clue... and with the speaker selector on A, there was sound! The A+B position is either not working, or two pairs of speakers need to be connected for it to work and I only had one.
I listened to music for an hour or so and the amp worked great, it's quiet and runs just slightly warm. There's a couple more things I want to look at, and also give it a well-deserved bath, but that will be for tomorrow.
