I could be wrong but I think Mike asked a legit question - don't see why this has to be turned into another thread where the comedians crap on 'high-end' systems or their owners.Why do lot's of people with high end boutique equipment seem to place all the amps and sources on the floor in a dedicated listening room? Usually, the equipment is on a 2-6" riser. Are these risers typically an isolation device of some sort? Are there advantages to this practice?
Nothing like attitude toward people who use newer equipment.....
I sometimes have amps on the floor for the following reasons;
- they are monoblocks and having them sit near the speakers and crossovers makes for very short speaker wire runs.
- They are heavy, awkward lumps and I like having them firmly planted on the floor, not high up on some precarious rack.
- If they are going to be high up, a rack that isn’t precarious is usually expensive and that is not where I like to spend money.
- I have them essentially in front of my speakers – I want them low, not in front of the drivers.
- I don’t play with them, just turn them on and listen – they don’t have to be easy to touch.
- I have a dedicated listening room where I just listen to music – my wife doesn’t care about aesthetics and my young daughter doesn’t play in there.
- I like how they sound on the floor with various isolation and coupling techniques.
You could say my turntable is on the floor too but I’m including the low Torylte stand and maple platform it sits on as part of the turntable assembly – always sounded better to me this way than on a rack.
I have an inexpensive Lovan racking system that could let me stack everything up high but I like it split in 2 positioning my equipment low – the stuff I rarely play with on the bottom shelves (DAC, phono-stage, tuner for 1 station, etc.) and the stuff I touch higher like a top loading SACD/CD player. Since the equipment is low (mostly out of the way of the speakers) with front-top access to the stuff I touch, I get to position the often used pieces like the pre-amp in the center and closer to the listening position – less of an issue with my new Joule Electra pre-amp that has a remote volume control but convenient none the less.
The equipment is mostly out of the way of the speakers, room tuning devices are a touch more effective, wire runs are shorter in some cases and isolation/coupling devices seem to do their thing better.
In a nutshell; it’s cheap, convenient and for various reasons lets my system sound better to me which is all I really care about in my room – music.
Huh??? x 2
I’ve read that shorter speaker wire is preferable to short IC’s but I’ve only done limited comparisons of this and only in low power SET tube based systems.So shorter high-level speaker wire runs are better than shorter small-signal wire runs for best fidelity in your experience?
Amp is cooler and happier =)
Hum. No super high end system here. But what's the temp difference between the floor and say three feet off the ground? I'm sure there's a difference, but if it matters enough to design your whole room around it, why not notch the a/c down one degree? Seems a lot easier. I just can't imagine that it makes enough difference in the real world to matter. But a lot of that "super high end" stuff has little to do with the real world.
Its that lovely reverse snobbery that AK is so damn famous for !
That clear enough ?
Crystal, however.....please re-read where I stated that my original post was a serious question.
