thick and thin speaker wire
well my speakers are about 5 feet apart and the receiver is on top of the speakers im just wondering if it affects sound quality and such.
Legendary speaker maker Roy Allison suggests 8 gauge speaker wire, no more, no less, length shouldn't be an issue. He also suggests lamp zip cord from Home Depot, same gauge. Keep the positive and negative consistent or the speaker will be out of phase.
He probably meant 18ga which is what lamp cord is.
And yes, 18ga will suffice for the majority of home applications.
I use quite thin 9 foot speaker cables (14 guage?) called Black Cat Silverheart. These replace 12 gauge Axiom Audio speaker cables and I have noticed an improvement in clarity, the highs are more extended and the bass is still strong. There is more to a cable than just the gauge. The Silverheart cables have silver wire (no surprise from the name), are constructed differently and have better connectors.
The Axiom Audio speaker cable is still a good cable, the Silverheart ones are just better in my system.
If you're posting the question, you are very likely not in need of speaker wires that alter the signal in lieu if tone or EQ control (this happens due to variations in the electrical properties of the wire).
Go with 16 or 18 ga. lamp cord, observe proper polarity, and you will be fine.
Oops yes 18, haven't had my coffee yet
Probably fine, but 16 AWG is not much more expensive and is readily available. Little overkill never hurt anyone. I tend to use 14 if I can although it is a jump up in price from 16. Anything more than that is wasted on 99% of the systems out there.
According to genuine :-) literature on the subject.
ONLY wire resistance is of concern in a speaker wire, resistance is a function of Gauge and Length.
Even 18 gauge is fine up to ~6 feet length
Roger Russell gives the following application for 18AWG speaker wire.
8 feet max - 2 ohm
16 feet max - 4 ohm
24 feet max - 6 ohm
32 feet max - 8 ohm
64 feet max - 16 ohm
*Total wire resistance should not exceed 5% of loudspeaker impedance.
