Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Nice looking speaker. I read up on this model, the official first production speaker by Jim Thiel from 1976, and it is designed to work with a special equalizer that comes with a set.
The seller doesn't have the equalizer... it's used to extend bass response down to about 30 Hz. So, using these may require cranking up the bass response on the pre-amp to compensate. Not sure if that'll result in an undesirable colorization of the sound.
The newer (90s) Thiels that have an equalizer, the equalizer is "optional", I don't use mine with the CS3.5, so it may not be a biggie that it is missing. If original drivers, I would go for it just to try them out.
