Thinking about a Marantz 1200
There aren’t many speakers the 1200 will not drive well. My JBL L-100’s are heavily modified with new crossovers and the port plugged to essentially make them acoustic suspension. I’m sure they are not as efficient as my Fortes, but the 1200 really rocks them. I can’t tell which set I like the best. They both sound great, but are very different. Right now, I’m using the JBL’s for rock - my main genre - and the Klipsches for most everything else.
Very cool.
Yeah, my KLF-30's are modified/upgraded to the point that they're almost not Klipsch anymore......but they are. Still Klipsch's design, values etc. but better parts and better cabs than stock.
I've been going nuts lately with restoring mid-70's Marantz gear and my speakers love me for it.
15334219170396404792616180806086.jpg Got my restored 1200B today. This is what I'm talkin bout.
Marantz warm, rich sounding....doesn't get much better for me.
This amp rules.
I actually just bought and had restored a 3300 preamp. I compared the 1200b integrated on it's own vs using the 1200b as an amp only and the separate 3300 pre feeding it. Although both units are recently fully restored, using the separate 3300 pre sounds marginally better for whatever reason. Could just be slightly different sounding but I like it.
I use EQ in the digital domain and I was once again reminded (proven) how valuable a tool it is.
When I was demoing the 1200b at my techs shop, I almost left it on the bench and just walked away from it. Thin, sterile and lifeless. It was very forgettable. I had to remind myself and take the chance that when I got it home in a system that was EQ'd to the room that the results would be better. They absolutely were. The warm, full lushness of the 1200b came shining through.
It's amazing to me how 40+ year old gear combined with modern tools can give such excellent results.....like they were made for each other.
Shameless plug for the Marantz 1200. My favorite integrated amplifier of that time period :D found one being recylced by an audio shop once (it wasn’t in very good shape cosmetically), got it running and had a blast with that thing. Oh the memories!
The 250's are very different from the 250M's. Also, some early 250's used germanium diodes which are very hard to find. I bought everyone I could from the only place on earth that seemed to have them back in 2004. I have both 250's and a 1200 and had a 3300. I preferred the 3600 I still have to the 3300.
Very nice! I’m going to be taking on a 1120 shortly and hope it turns out just as good. Can’t wait!
I have an 1120--sometimes used in my bedroom. It's a very nice unit that pairs very well with a set of Altecs from that era or AR's. JBL100's if you like the bass they produce also go well with it. Find a nice 125 tuner to match it and you'll be very happy with it.
I believe they are shorting plugs. I guess I'm not sure of the purpose. Is it to eliminate hum when the inputs are not being used?
They are indeed shorting plugs and they go on the phono inputs if they aren't being used so you don't get any feedback from other gear. Most of my units still had them--none of the 1060's did, but all of the bigger ones did. I gave the 1060's to my kids as their first stereo.................
Steven,
In your 1200,
I used a lot of WIMA MKS2 and Vishay axial caps(both expensive) but they are worth it.
Keep in mind also that the while the 1200 is 100wpc , the 2325 (I just finished two 2325 restorations in a row) cranks out 150wpc all day long!
Bob
If the 1200 has the 250 amp, which it does, it puts out a rated 125 watts per channel at full output w/o clipping for two hours. IN reality, they are capable of around 150. Given a proper speaker (96db or better), you will never get that high. If you aren't blowing your brains out at half volume from anything other than the phono input, something isn't right. I own two 250's, two 240's and one 1200.
The rail voltages are different between the 250 and 1200.
The specifications, including rated power (at various load impedances), are listed in the relevant service documents.
Tom
Out of curiosity, since I have one sitting on my shelves awaiting refurbishment, could one theoretically change the 1200 voltage rails to match the 250/240?
Theoretically, replacing the power transformer could increase the rail voltage. I doubt that you would hear a difference due to the slight increase in power. I don't know what this would do to reliability.
From Wikipedia:
Perceived "loudness" varies approximately logarithmically with acoustical output power. The change in perceived loudness as a function of change in acoustical power is dependent on the reference power level. It is both useful and technically accurate to express perceived loudness in the logarithmic decibel (dB) scale that is independent of the reference power, with a somewhat straight-line relationship between 10 dB changes and doublings of perceived loudness.
From Wikipedia:
Well, yes, I am familiar with db and what it takes to double effective loudness. The extra 25 watts allows for more headroom. I have a couple of spare 240/250 transformers laying around that are just fine--they don't seem to wear out--ever. The 240's were sacrificed in order to have complete and rebuilt spare boards for the others that I have. The boards have been rebuilt and are "ready to go". I did so, so as to have a "just in case" sort of thing when I'm 80 or something.
Got my 1200b down in my workout room paired with a restored 3600 preamp. Man, for only 100 watts this thing really has some balls. It's got power that rivals my high powered Crown amps.....not quite as loud but has the headroom. Full, warm, rich and powerful sounding. It can really move those woofers.....
Marantz routinely downgraded the power capabilities of their amplifier (sections). This was well known at the time. They also were the company that set the "Continuous RMS power at watts" standard. Even back then companies were using the peak watts bullshit to set their amps power rating. Marantz never ever listed "peak watts" but only the wattage that could be maintained for two hours minimum at full rated (by them) output without clipping. Crown, Phase linear, SAE and others all engaged in the peak watts crapola. Actual testing of 250 amps shows they are capable of quite a bit more without clipping (about 145 watts) and doing so at .003% total harmonic distortion ratings.
Phase Linear, in order to appeal to the "bigger is better" crowd, built huge chassis with nothing but dead air inside. I have one of their TOL preamps. it is gigantic and has vritually nothing inside. All that is in it could easily fit inside a 3300-3600 chassis with room to spare. I do not like it and only keep it because of its phono stage which allows for adjusting the capacitances of MM and MC carts. I fancy the idea of transplanting that phono section into something else one day.
"Marantz, We Sound Better"
Hi fellow AKers, does anyone have a close idea of how many of the 1200b was produced,I have one that was "precision crafted in the USA" as Marantz used to put on the serial # tag on the rear of the unit's. I know most were produced in Japan,so I believe I recieved an early production model.it has been restored by a friend and excellent electrical engineer. Todd D. I believe all the caps replaced were nicheion Capacitors. And Todd also rebuild a 120 tuner ,alines,calibrated.. I love the sound crisp,warm ,non fatigue listing. So if anyone has an accurate estimate, it would be helpful . Thank you fold stat safe and healthy everone
I have one in my collection that needs to be rebuilt--born in the USA.
All of Marantz "top of the line" were made in the USA through 1979 as far as I know. It was their second tier line that was made in Japan. And that occurred after the tube tuner fiasco that cost Saul a part of his company. Japan Radio was owned by Marantz, later spun off in the 1980s and then rose up and bought all of Marantz world wide and went back to producing a super high end line again. Now they are under one umbrella with MacIntosh and some other second tier company whose name escapes me at the moment. Over at tapeheads, some idiots there insisted Marantz was all Japanese junk. Morons had no clue as to what they even talking about. Screamed and shouted when I posted pics of the back sides of my 250's, 240's, 3600, 3300, etc.
i own a restored marantz 1200b compared to my old 2252B it blows it away kilometers far, easy listening, non fatiguing, great great bass, nice to undersanting vocals great preamp, but its not perfect has it flaws but for me is enough. many tech ive talked had complaints against the 1200 pre wich is they say is not that great and i agree but as i said to me is more than enough i really like it(theres some other brands sansui, technics etc.. witrh better pres even my 2252b has a better pré according to my tech wich i agree at some point).
