The green one is C605, 0.068µƒ, Mylar. Find it on the "X-Ray" (your first pic, or page 9 of SM) and identify the other components it is tied to, like TR602/B. Now find it on the schematic on page 13 to get the value and any identifying marks. The key (lower left corner) identifies the small circle in a circle as Mylar. Read the schematic carefully - it looks like the mylar symbol is associated with C604, which cannot be because that is clearly an electrolytic.
I am confused about the other one. The 103 in your pic identifies it as 0.01µƒ, but the schematic says C601 should be 33pƒ. The "X-Ray" also shows R601 and R602, which are also in the schematic, but clearly NOT on your board. They should be where the 'circled' B is in your pic. I'll defer to Kev here, but I'd suggest you go with the board as Sansui is well known for not updating their service manuals and schematics.
Transistors: My suggestion is to start with data sheets for the 'originals' so that you are familiar with the specs.
www.alltransistors.com has been a good source of information for me. Go to their main page and enter the full TR name (2SC1845) in the search window - it will return a list of all the versions in its database. Click on the one you want and the next page will give you info on that TR, links to datasheets available, and a link to "Equivalent Transistors". Click on that and you get TR info in a spreadsheet format. You can hilite what you want, copy that, and paste it in your own spreadsheet, then correct the formatting. Look for TRs with about the same, or better, specs than your originals.
Also do a Google search on AK ("site:AudioKarma.org 2SC1845") to see if any posts have suggestions for suitable subs. Markthefixer has done a lot of research on this.
Now you can look at places like Mouser, Digikey, MCM Electronics, On-Semi, or others, to get availability and prices. Think about the fact that S&H charges can mount up quickly, so you might want to hold your orders until you have larger numbers of items. I decided to just wholesale replace TRs Caps & Resistors in the Audio side of the main board in my G-4700s and G-6700, so I made some large orders.
I think this will be post #999 for me, so the next one will be a big deal (haha).
Goog Luck - - -
