C version of RTA-12 are unique...
Although I have never heard these, I think they should sound quite similar to my RTA-11's, which seem essentially like the same speaker with the tweeter and crossover mounted in the cabinet instead of on top. Mine look sort of like overgrown Monitor 10's, but they have similar crossovers as the RTA-12, with labeled left and right speakers.
If all of your mid/woofer drivers are in good shape with no magnet shift, you are a very lucky man. You should immediately pull them out and run a good bead of JB Weld between the speaker basket and the magnet assembly to prevent magnet shift as you move the cabinets around.
There is a ton of info and mods for these detailed over the Polk Audio forums. I have done a lot to mine, including converting all of the wood screws to t-nuts/machine screws, recapping the crossovers, damping the speaker baskets with sound insulation (dynamat or similar), and replacing all the gaskets. I think all of these were worthwhile improvements, and were easy to do.
I haven't (yet) owned any speakers I like better than my RTA-11s. They produce a very wide soundstage that I find very pleasing to listen to. I've been A/B'ing mine with a pair of Infinity Kappa 6's, which are very good, but I give the edge to the Polks. I would love to hear the RTA-12s, since they were the TOTL of the series. Congrats on the find!
Yes, all drivers/tweeters work.
I have over 8 pairs of Polks that need JB weld or epoxy, dynamat, crossover etc...
Man, that means a lot of time that I don't have. :sigh:
Never heard RTA-11's so not sure how similar they sound but read my response below on what's unique to the C version of RTA-12's.
Congrats! Would love to hear the 12's. I'm finishing a recap on pair of Monitor 11's I picked up earlier this year. They have the Peerless tweeter and sound wonderful.
They may give your A400's a better run with recap and Polk's replacement tweeters :scratch2:
http://www.audiokarma.org/forums/showthread.php?t=437262&highlight=polk
http://www.audiokarma.org/forums/showthread.php?t=440579&highlight=polk
Re-cap is in the plan but not soon.
A400's are very detailed yet soft and smooth. It's like listening to live music.
RTA's sound little punchier and metallic.
I'll compare them later in proper setup.
Current living space is not that big to experiment placement options.
You might be surprised. I think the recessed, top mounting of the tweeter makes a considerable difference in the imaging. I compared Monitor 10s when I bought the 12Bs and the difference was substantial.
Cheers,
Otto
I agree but it's not only due to top mounting tweeter.
From my online research, RTA-12C's are the best in RTA series and they are the only ones that are really time aligned.
All other RTA series including original RTA-12 mimic that name but they are not mirror imaged and not truly time aligned.
RTA-12C's actually are mirror imaged and have different different crossovers for left and right speakers/mid-woofers unlike other RTA's that have single crossover.
http://www.polksda.com/pdfs/1985Sales.pdf
It mentions RTA-12C uses unique technology for imaging and clarity that was not in other models.
It handles upto 500 watts of power.
It utilizes phase-coherent open air driver mounting in a mirror imaged, fullsize floor-standing configuration.
This model won the AudioVideo Grand Prix Speaker of the Year Award and was selected for the prestigious CES Design and Engineering Exhibition as one of the industry's most innovative products.
However, it's only true on the
B and C versions where outside mid woofers drive 60-600HZ and inside mid woofers drive 60-2000HZ.
This applies to RTA 12Bs and Cs.
--> The early RTA 12 (the ones without B or C) DO NOT roll off the outside driver and are not mirror imaged. They have only one crossover.
