It's an aftermarket belt, but I have it dialed in at 33.33 rpm, so I doubt it is out of spec in any way. In my experience, belts out of spec in any dimension by microns affect the speed in startling ways. Frankly, yeh, the right front spring acts as if the belt is too tense, but I can't imagine that a non-spec belt would provide 33.33 rpm. Also Dean Man reflected the advice to turn the springs' "base points to the platter bearing." Someone else--I think it is the maker of the replacement spring kit (mine still has the original springs, again)--said turn the "strong side" of each spring toward center, and I did this, to no effect on my attempts to tune the 150 so that all springs bounce vertically.Stock Thorens belt? (Or Thakker?) That's key.
D
All good, yes: this 150 Mk. II is speed correct (and actually was previously, with the "too tight" belt)Good luck and hope you get it right soon!
