Greetings, a newcommer here.
I have undertaken the 'motor ticking' repair caused by worn bearings - drilled the spacers out, opened the motor and placed a washer(will post pictures in the futture when everything with the TT is sorted out). Closed the motor, soldered the wires and then plugged and switched on the turntable. The motor was runing so smooth and silent that I wanted to hold it in my hand and see if I could feel any vibrations but before that I cheked with a lamp tool for voltage leakege or any shorted metal parts. And as it is sometimes at the end comes a bad surprise - the motor housing was shorted showing full voltage(thank god i did not touch it) and logically the plynth and so on every metal part in the chain that comes in contact with the motor.
I think I pulled off the mechanical part quite ok but face now electrical problem and i'm confused how can the motor run so nice and in the same time every metal part be shorted..
The windings were encapsulated in plastic so it is unprobable that they shorted. >>
I found this motor wiring diagram on the net >>
In my case it is the 220V version.
Here the wiring of the motor>>
Didn't have time today to find what exactly is going on, but tomorow I plan to unsolder the motor, check the resistance of the windings(I read in other post it shoul be around 4,6k).
Should the motor wires have continuity, if yes which ones?
Anything obvious or else that comes in mind that I should check?
Anyhow I will update my findings here, so this thread will be kind of logbook for me.
