I just started this project today, I am using a kit from Audio Silente along with his MK2 motor post upgrade. I have an early'ish MK1 ser# 179xx, yes it has the nylatron main bearing sleeves, Replacements coming as well.
Looking at my rotor (the part that rotates in the motor) I have a 3-4mm wide black stripe around apprx. 1/2 of the diameter of the rotor near the bottom of it. It is not a wear mark but appears more like a thin coating of something, maybe old dried oil? It width is pretty consistent so I don't think it is that. 70% isopropyl alcohol did not phase it, before I get more chemical aggressive does anyone know what this maybe. I don't think it should be there and I think I should remove it.
