This is a puzzler.
I have a TD-124 here for cleanup and some parts updates (motor springs, plinth, arm change, etc).
One of the things to be installed, was a new idler wheel. This is one of those, with the machined aluminum hub, and a fat o-ring as the friction surface.
I got everything installed- and when I started it up, it couldn't be brought up to speed. The speed adjustment seemed to do virtually nothing- or, at least, it didn't get even close to the correct speed (way too slow).
As it had been working- I tried changing the belt- no difference.
I then took off the new idler wheel, and put the original back on- voila, CORRECT SPEED.
The owner just sent me ANOTHER idler wheel- an Audiosilente, which apparently is very highly regarded. Put it on- SAME PROBLEM- way too slow. And again- putting the original idler wheel back on, restored speed to its normal adjustment range.
Anyone seen this before? The only thing I can obviously see, is that the new idler wheels seem to be ever so slightly larger in outer diameter than the original (I mean, by a few millimeters), and the friction surface is round (o-ring outer surface) on the replacement idler wheels (as opposed to a flat surface on the original wheel).
I made sure the idler wheels are all installed in the correct orientation (the extended part of the bearing hub facing down). Just like the original was installed.
I'm thinking, that since the original idler wheel works fine- there's fundamentally nothing wrong with the turntable...
Any ideas?
Regards,
Gordon.
Any ideas?
Regards,
Gordon.
