After 6 years, the Thakker Belt on my Thorens TD-124 MK 1 has degraded. Shedding belt debris and deposits on the pulley:
The belt still functions. In fact, the only reason I lifted the platter was to adjust the Eddy Brake because the table has been running a little fast lately and is beyond the normal range of adjustment for the Eddy Brake. Hmmm.
The Thakker belt hasn't stretched, snapped or fallen off but I think the deposits on the pulleys can't be good for speed stability. I have no way to accurately measure speed stability, so I can't state with certainty that the deposits have any effect. The strobe dots don't sway or dance. More than likely, if the deposits have created any instability, it has occurred over time too gradually for me to notice.
If the deposits have increased the overall diameter of the motor's drive pulley seen in the photo, I think that should increase platter speed. What a coincidence!
A member whose opinion I value greatly uses a Thorens Branded belt (which I just ordered along with another Thakker).
An article I found at theanalogdept regarding the Thorens OEM belt states:
https://www.theanalogdept.com/td124_belts.htm
Maybe the Thakker Belt held up admirably after 6 years.
Other options I see are:
Schopper:
https://www.schopper.ch/index.php?page=Belt
Hanze:
https://shop.hanzehifi.nl/product/thorens-td124-hanze-belt-low-noise/
AudioSilente:
http://www.audiosilente.com/spare-parts-thorens-td-124-td-135-td-184-td-121-td-224-drive-belt.html
So I'm wondering....what is everybody else using? Any opinions would be appreciated.
Thanks in advance.
Rich
Edit: Have you checked your belts after a few years to see if they've degraded like the Thakker and OEM Thorens Brand?
If so, what do you estimate is their belt life?
After 1 year, drive and driven pulleys were cleaned after use and it was noted that there was an extraordinary accumulation of belt shedding debris. Then again, after cleaning of both pulleys, and the belt, and then put back into use for 1 week. The oem Thorens belt (with Thorens logo) again shed its material excessively onto the pulleys while in use.
Schopper:
Hanze:
AudioSilente:
Thanks in advance.
Rich
