Timothy Flath
Well-Known Member
There's been no impact on the shaft so I assume it's a worn bearing. It's not knocking at all times. It sometimes starts when I use a cleaning brush and then it goes away. I assume it will only continue to get worse over time.
A thrust bearing "may" be helpful in your case then. It lifts the shaft up off the base of the motor with the use of a very hard ball bearing and lubricant to smooth out the rotating shaft. Linked below is one of the ones I bought. I also heard Dave at Vinyl Nirvana used to sell a similar one. Not sure if he does anymore since he appears to have scaled back on servicing some Thorens models (according to the V.N. web site but worth a look if you are in North America). SRM-Tech is in the UK so shipping time is longer especially to here on the west coast of
https://www.ebay.ca/itm/SRM-TECH-TH...p2349624.m46890.l6249&mkrid=710-127635-2958-0
