andylsun
I recently installed a genuine Thorens belt onto my TD-165 to replace the old belt that was present when I bought it.
Now, on startup, the suspended chassis oscillates while the motor gets up to speed. There's clear movement in the platter and the tonearm of at least 3-5mm. It doesn't seem to be in one axis, and does settle down when normal speed is reached.
As I've not owned one before is this considered normal with a new belt, or a sign that my suspension is not set correctly. Or could it indicate a problem with the motor start capacitor. Spin up time is good taking about 7 seconds to get to 33rpm.
The bearing well has been cleaned and lubricated and the motor is very quiet. Nothing rubbing or catching.
