avantbored
Hi all,
Continuing to troubleshoot an issue I have on my TT, and I've noticed something odd (to me). Hoping others can shed light on this. I provide a narrative of my troubleshooting journey, but if you want to jump down to get to the meat of the question, it is #4 in this post.
Stereo Set-Up:
Thorens TD-165 || ATVM95SH
Nakamichi PA-7AII
Nakamichi CA-7A
1. Stylus Quivers
This troubleshooting journey started with my stylus quivering/shivering on playback. But my own research, backed by helpful posts, found that the most common issues of this is either a a) compliance issue, b) a failed suspension, or c) a bent bearing.
A) The ATVM95SH is a common combo with the stock TP11 tonearm. I have not had this stylus shivering issue from the beginning (happened within ~200 hours of listening). So I don't think it's a compliance issue.
B) As indicated above, this is a relatively new cart, well below the halfway mark of its ~800 hr. listening life recommended by AT. I've eliminated this as the cause of the stylus quiver problem; I revisit this below.
C) My bearing is fine!
2. I Decide to Send to Audio-Technica, But Change My Mind
I got really frustrated, so I decided to send in the cartridge to AT for a repair estimate. I'd packed it up, then resolved to try one last thing. Slide the Preamp to the right so it no longer sits under my TT (which is on a wall shelf). I also widened the speaker placement. Because I'd removed the cartridge, I also unplugged the turntable.
3. No More Quivers (Kind Of), But Static Electricity Persists
So I rearranged the set up, re-aligned the cartridge, and plugged the turntable back in. Suddenly, no more quivering problem (as described in 1B). I'm pretty confident that my quivering issue is not with the cartridge or stylus or the mechanics with the turntable itself, but with power.
4. What's Going on with all this electricity?
The plastic housing on the left channel of my RCA terminal is cracked. I notice that after playing 1-2 LPs, the latent hum is loud (~20-25% volume). When I unplug/plug it back in in the preamp, the hum is only audible at ~50%.
Other electrical phenomena: Electricity discharges through the tonearm and when I lift a record from the platter.
Plugging/unplugging the turntable has seemed to get rid of the quivering issue. But this is not ideal, and unsustainable. I can hear static electricity discharge through me when I touch the tonearm pole.
The Question: Can this cracked RCA terminal affect the circuit, thus perhaps causing this quivering problem through some kind of extra resonance?
Stereo Set-Up:
Nakamichi PA-7AII
Nakamichi CA-7A
1. Stylus Quivers
