p.robustini
I've been playing a while with my Thorens TD-165.
I added damping material to the inside of the plinth walls, to the bottom of the faceplate, and lately even to the bottom of the sub-chassis (also around the bearing well) - using a combination of adhesive tar sheets and white tac.
I have been replacing the cables, using both microphone and video coaxial cables.
I know someone does not like the idea of replacing the stock cables if they are fine: they were designed for that TT, with proper length/capacitance.
Some believe dampening the plinth may change the resonance of the TT and thus deaden the sound.
I have done my usual "mods" with a TD-160, too. I went to the extent of installing Belden 1505F cables.
Now I've come across a stock TD-160 with cables in good conditions. I'm thinking of leaving it almost as it is, maybe just partially dampening the subchassis and the bearing well - maybe I will ad some adhesive tar sheet to the faceplate's underside. But I want to keep the stock cables and compare the sound to the dampened TD-160 before I decide which one to sell.
I'm starting to like the idea of keeping the TT as stock as possible, at least for a while...
What is your opinion and/or experience about this?
