Spent a good amount of time on AK and other sites but can seem to troubleshoot this. I should note that this is my first Thorens TD124 mkII so I’ve never experienced one in top working order.
When I bought the turntable the idler wheel seemed to have issues with engagement. I’ve since gone through a detailed cleaning as per the many resources online and while everything is running and functioning great, the idler wheel does not engage the inner platter. It just sort of flops around (I understand that with the platter off it will not fully engage).
I’ve cleaned, lightly polished and lubed all linkage parts and there is no gummy build up of old lube.
Could it be the spring has lost tension? Does the underside of the stepped speed control cam have to be greased?
Any help would be appreciated!
