Thorens TD124 Tonearm advice
tmesselt
My tonearm was damaged beyond repair while my td124 was in storage. So I’m in a dilemma to either get a new tonearm and cartridge or get an entirely new setup. I was going to get a Jelco SA750 as I already have a tonearm board for the td124 but it appears they are out of business and haven’t been able to source them.
Tonearm and cart budget would be about 1200.
If I get an entire new turntable budget would be about 2500-3000 and I’d probably sell the TD124.
The rest of the setup is old McIntosh tube gear and I have been digging the vintage gear. Not opposed to a modern turntable though.
That sucks that you’re arm was damaged, can’t help with the decision but if you decide to sell drop me a pm, might be interested…
VR
Andy
There has to be better options than selling your TD 124. Can you borrow a table from a friend until you can build up your replacement arm and cartridge fund? What about buying a temporary lower budget used table until you can repair the Thorens? You could resell the budget table later and recoup some of the money or all if you find a good bargain.
Your vintage TD 124 is becoming more valuable everyday. To let it go would be a shame.
What tonearm did you have that got destroyed? Were you satisfied with it?
If so, would it be possible for you to get the same arm used/undamaged?
If your 124 table is still in good shape I think I'd be tempted to throw a different arm on that vs selling and getting a different table.
Thinking I just needed a little encouragement to keep the td124. Just need to figure out what the new tonearm and cart will be!
I had a Grado Micro Control Tonearm, it came with the he turntable when I purchased it. I actually think some wood filler could repair it but it’s more than I want to take on. I was always wanting something more from my vinyl setup and that was one of my upgrade possibilities.
Not enough to get it again, I would like to try something new!
I think i just needed some encouragement to keep it and get it going again, thanks!
VR
Andy
Appreciate that! I’ll let you know if I end up going that way. I really do like Thorens record players.
You have lots of options so just figure out which one fits you best. I’m just looking for a new project….
Good luck,
Andy
Tell us more about your Mac gear.
Sure!
i have a C20 for the preamp and one mc240 for the amp. This feeds a pair of Klipsch Heresy. Don’t love the speakers. Really want to get something to match well with the tubes. After I get this vinyl situation figured out they are next!
Sure!
It would be hard to better the TD124 with that set-up.
Yes, you need a 9” arm unless you use an extended armboard / custom plinth.
If you want a Jelco arm suggest you go to AK Bartertown and place a Want To Buy (WTB) ad and also over at US Audio Mart.
Many 124 owners use the SME 3009 arms as well.
The SME 3009 comes in 2 versions, the “improved” effective mass is low, then the “non improved” effective mass is medium, each variable with the headshell type.
Have a “ non improved” myself that gets moved around a bit, it’s currently residing on my Fairchild 412
