Found this and wonder if anyone has tried it? I'm never going to play anything at 16 rpm, but 78 would be really useful. It applies to the MkI which is what I have.
THORENS TECHNICAL BULLETIN # 4 (dated 5/19/69)
SUBJECT: TD 125 CONVERSION TO 78 RPM
The conversion of the THORENS TD 125 Electronic Turntable to 78 rpm may be accomplished two ways:
1. Direct replacement of the16 rpm speed with 78 rpm, whereby the speed selector sequence becomes: 78, 33 1/3, 45.
2. Interchange of speeds, whereby the 45 rpm speed position becomes 78 rpm and 33 1/3 and 45 rpm are moved to the left, eliminating the 16 rpm speed. The speed selector sequence then becomes: 33 1/3, 45, 78.
NOTE: The introduction of the 78 rpm speed will result in an alteration of the phase relationship for the motor. Erratic starting may occur. Always start the turntable at the 45 rpm speed then switch the speed selector to 78 rpm.
PARTS REQUIRED:
2 0.033 ufd/200v
1 50 ufd/70v
METHOD ONE (1):
CHANGE: PART NO. FROM TO
C 4 250 ufd 50 ufd
C 8 0.2 ufd 0.033 ufd
C 11 0.2 ufd 0.033 ufd
METHOD TWO (2):
C 4 250 ufd 100 ufd
C 5 100 ufd 75 ufd
C 6 75 ufd *50 ufd
C 8 0.2 ufd 0.1 ufd
C 9 0.1 ufd 0.075 ufd
C 10 0.075 ufd *0.033 ufd
C 11 0.2 ufd 0.1 ufd
C 12 0.1 ufd 0.075 ufd
C 13 0.075 ufd *0.033 ufd
* Additional parts
ALIGNMENT:
FOR METHOD ONE (1):
a. Connect an AC-VTVM, on 30 v scale, to the Blue and Black motor connections on the printed circuit board. Adjust A-16 for maximum reading, approximately 12 VAC.
b. Set the fine speed control to the mid-position, place a 78 rpm stroboscope disc on the turntable and adjust F-16 for a stationary stroboscope pattern.
FOR METHOD TWO (2):
a. Connect an AC-VTVM, on 30 v scale, to the Blue and Black motor connections on the printed circuit board. Adjust as follows:
A 45 Maximum, approximately 12 VAC.
A 33 8 VAC.
A 16 5 VAC.
b. Set the fine speed control to the mid-position and place a 78 rpm stroboscope disc on the turntable. Adjust as follows:
F 45 Stationary strobe pattern at 78 rpm on strobe disc.
F 33 Stationary strobe pattern (lower) in illuminated turntable viewer.
F 16 Stationary strobe pattern (upper) in illuminated turntable viewer.
NOTE: The stroboscope pattern is best viewed under fluorescent light. The adjustments should be made with a non-metalic alignment tool such as a nylon TV alignment screw driver.
PARTS REQUIRED:
2 0.033 ufd/200v
1 50 ufd/70v
METHOD ONE (1):
C 4 250 ufd 50 ufd
METHOD TWO (2):
C 4 250 ufd 100 ufd
C 5 100 ufd 75 ufd
C 6 75 ufd *50 ufd
C 8 0.2 ufd 0.1 ufd
* Additional parts
ALIGNMENT:
FOR METHOD ONE (1):
FOR METHOD TWO (2):
A 33 8 VAC.
A 16 5 VAC.
