Pieman2016
Just got hold of TD160 mark 1.
I have oiled the main platter bearing and dropped a tiny bit of sewing machine oil on the motor spindle.
The TT has the original Thorens arm and headshell with a Shure M75ED cartridge and stylus. I think this could be the original cart/stylus.
I have set the table up and all seems to be playing well.once the ground connection on the RCA was twisted to make a good connection. The sound is not bad reasonable bass, good stereo separation, High frequency sound is not really there much. Could this be a worn stylus?
These are the things I plan to do to improve things beyond the stylus.
0) Make wall shelf with some paving stone or granite shelf?
1) Set up the ground from the arm on a separate connector direct to amp bypassing everything else?
2) Replace power cable and earth sub chasis and chasis to mains ground. Use this ground for phono connectors?
3) Replace Phono cables maybe?? and definitely phono connectors
4) Replace the cart /stylus which will be a priority.
Given that I am not using really audiophile amp/speakers (Cambridge A5 and Mordant short speakers)
Should I just keep the M75ED cart and just replace the stylus. Can a better stylus be put in this cart rather than a stock Shure M75ED?
Can anyone suggest a much better cart/stylus for sub £100/ $150?
Many thanks
Many thanks
