Good afternoon,
I've just replaced the plinth on my TD160 and have moved the metal base and the sub-platter over successfully.
Or so i thought, until i plugged the TT back, turned it on and now it doesn't turn at 45rpm.
With the belt attached round the inner platter and the belt spindle, 33rpm rotation is fine.
Switching the switch to off turns off the motor, as i expect, but switching it to the 45rpm position does not turn on the motor, so no power to the belt spindle, so no rotation
Last time i used the turntable, everything was working fine, so i don't know what has happened for it to stop working now
I'd be grateful for any ideas as to why this might have happened and how i can fix it
thanks
Simon Hume
thanks
Simon Hume
