oztayls
Member
Hi all, I'm looking for some advice from Thorens owners.
I've just bought a nice TD160S MkV on eBay and fortunately it has arrived in one piece. I've not owned a Thorens before. It has a Grace 707 tonearm and the RCA leads are also Grace. After having spent a few hours putting some things right, for eg. the platter wasn't level and not bouncing correctly. There were a few other minor issues as well, but I've managed to sort them out and get it set up. I plugged it in to my old Yamaha CA 610 amp and turned it on. First off, there is a bit of hum through both speakers, but not only that, I can hear a radio broadcast!
I noticed the tt did not have an earth connection and when I had the back cover off, I noticed that it is earthed through the power point's earth pin. Could this be causing some kind of earth loop, or is the problem the old RCA leads that may not be as well shielded as they should be? The cable doesn't look to be in bad condition though.
Would it help if I installed an earth wire to the metal chassis and connect that to the ground on the amp? Is it OK to leave the earth pin ground in place or should I disconnect it?
Any help would be appreciated.
