p.robustini
Hi guys!
I was experimenting with thinner mats than my 5 mm Funk Firm Achromat that got a little warped. So I noticed that even with the tonearm pivot all the way down and a 3 mm spacer over the cartridge, the tonearm is still sloping towards the headshell. To be honest, even with the Achromat the wand is still dipping.
Looking closer, I noticed the tonearm base is a bit tilted inward so the arm’s pivot is slightly leaning. That may result in the pivot being also too high…
I will open the deck as soon as I can but in the meantime I’d like to have any suggestion, since I’m not sure it might be a matter of regulating the springs: the platter is horizontal and the tonearm base is not, as you can see from the attached photo.
Maybe there is a way to better fix the tonearm’s base to the sub chassis?
Thanks!
Thanks!
