I look at this mod in horror, because as a person who works on Thorens models almost exclusively, I've seen it botched many times. PLEASE only do this if you have a top mounting cartridge OR your inner sled is stripped beyond repair. As one poster said, screw kits (good ones) are available cheaply...that's the way to proceed if the sled is good and your cartridge is bottom mounting. Pleeeeease.
And does not hack up original headshells.
View attachment 740704 I went with this instead
Recommended. Keeps original headshells original. Better than stock for your needs and keeps your original arm.
^^^^^ If I didn't have an original head-shell I would use one, no question.
However, IMHO, if we're going to keep the deck as original as possible, I prefer this look:
Again, IMHO, I find a certain visual charm to the original head-shell, I think it's one of the nicest looking out there and I also think it's half the beauty of the entire deck (much like the front grill of a car). What I have done is to remove two pieces which can be put back (they snap in).
Ok.I kept 2 of the original headshells and will probably use them if needed. My table has a custom plinth so it has lost the original look anyway. The Schopper headshell looks a little more modern and does allow for azimuth adjustment.
I'm guessing it prevents long screws inserted from the bottom from puncturing or denting the aluminum foilcal. It may also help dampen the threaded magnesium plate and keep it from rattling inside the HS.what does that part do anyway? I don't see the function.
I don't understand your question but I will attempt to answer what I think you are referring to.I did the same mod but took it all the way. The thin metal Thorens badge was damaged when I got it: someone forced too-long screws and punched dents into it, also breaking the glue-bond, it was barely hanging on. I removed it completely — with those dents it was ugly anyway. I have several very nice top-mount-only cartridges (VDH, Madrigal, Dynavector) and after the mod I could mount them in the Thorens shell as easily as a conventional shell, and adjust them from the top.
With the mod described in this thread, how do you do the protractor/alignment procedures, which require many little back and forth adjustments till it's spot on? Do you have to do all that from the bottom? If so, isn't that awkward?
No, mine is not original anymore, and for some people "originalism" is holy writ. But it doesn't bother me, it's just a personal preference — especially when it was a bad design to start with. It may affect resale value, but if I want to sell it I can find a new Thorens badge online and — voila — it's original again.
It's all a bit academic in my case because a) I replaced the Thorens arm long ago so it's not an issue, and b) I don't even use the table currently (but it's a TD125 and I love it, I hope to keep it as a superb back-up).
Despite being academic, I thought I'd share because these mods and tweaks are one of the great things about vinyl: creative engagement by us, the users. Instead of just pushing a 'start' button, what fun is that? And the best Thorens tables, being so soundly engineered, provide a great starting place for incremental improvements both sonic and aesthetic...
It is a Schopper replacement for the TP-60. Search on Ebay, they are available. I have since changed to an SME M2-9 arm so I no longer have it but it worked will on the TP-16Hmm. How did this managed? Is this the TP16 IV arms -headshell? And is the geometry like original now?
