Thoughts on AudioSource EQ-ONE
Think you're a little mixed up on this one. The EQ in Ferris Bueller is an Audio Control C-101(the big buck one). Audio Source is more of a budget brand, but still pretty good. I have a C-101 series III in my main music system, purchased new in 99' for about $450. I also have an Audio Source EQ-101 in the the other room purchased new a few years ago for about $80. Hate to burst your bubble, but guess the wrong guy read your post. I'd still keep an eye out for a C-101(if anyone's willing to part with one), if only for the switchable 3rd order 18db/octave sub-sonic filter. Does a steller job eliminating turntable feed back problems.
I know this is an old thread, but needs a correction. The audiosource Eq-one series II is the correct model for the movie. Not the audio control c-101. I’ve read this thread and second guessed myself and almost bought the C-101 instead. I did some research and found this picture of the movie. Thanks
How does it need a correction? The person that said it was a C-101 admitted he was wrong. No one else said it was a C-101...
I have a AudioSource EQ 10 I hooked up and it was working. I was about to set it in the rack and see what it looked like and when I went to turn it off I got some noise and screeching thru my speakers . I cursed and turned it back on with my amps off and since then the "PAUSE" button light will not go off. ive pushed the button and it bleeps but wont seem to go off and now the graph is not doing anything
help!!
I have a AudioSource EQ 10 I hooked up and it was working. I was about to set it in the rack and see what it looked like and when I went to turn it off I got some noise and screeching thru my speakers . I cursed and turned it back on with my amps off and since then the "PAUSE" button light will not go off. ive pushed the button and it bleeps but wont seem to go off and now the graph is not doing anything. help!!
For the most part we've been discussing the model EQ-ONE. Is that the one you meant? I'd chime in with a thought on that.
But, if you are truly referring to an EQ 10 then I'll defer to someone else.
If you’ll pardon the resurrection, I’d be interested in knowing your thoughts regarding the AudioSource EQ-ONE.
I’m no audio file but I love my music and I’ve always appreciated a little more control over the sound. I picked one up 10 or so years ago. I wasn’t certain what I was looking for and as I recall the price was right. I used it for a while until I decided I wanted to have the left and right channel adjustments next to each other. I found that feature as well as two tape monitors on the Yamaha GE 60 and picked up one of those. Used that in the basement for a few years and loved it. That is until the wife spent way too much! Like way way way too much time in the house and in the living room above me. The entire system got the axe ( disassembled ) when the complaint department issued warnings that “Disturbing Sounds were Interruptive“ while trying to sleep yet another floor up. And for crying out loud it’s a tank of a house built in 1941 but the HVAC ducts were my nemesis. Now it’s just #AllDetatchedGarageAllTheTime! And for this duty the original workhorse, an empire scientific GX 200 from the late 70s? was resurrected and continues to perform flawlessly under these adverse conditions. Thank goodness for the window AC, space heaters and the double head Mr. heater.
TIA for any feedback.
I like it too. It doesn't get as much use as it used to. But, it's still hooked up to the 'big' system.
I got a kick out of this. Reminds me of my child rearing years with the, now, ex. I got the unfinished attached garage and the car had to stay outside.
I have one in my main system also. Had the BSR and IMO, the Audio Source us far better made. I use a condenser mic with it for setting up the room. Its actually a MODEL ONE series II
Yeah, I've got one. Paid $299 in '82. Still got the instruction manual. Want a copy?
Brian
Hi Brian, I know your reply is 15 years old but in case you’re still active and have a PDF of the instruction manual, I’d love a copy. Thank you!
If anyone has a service manual, I would love to get a copy. I picked up an EQ-One today and am going to recap it. Already started. LOTS of small e-caps: 0.15, 0.22, 0.33 etc. Some WIMA's should be an improvement.
I found this manual which has a schematic. You'll need to tilt your head slightly to read it. lol
