goldwax
dozy ming-mong
These caught my eye for an upgrade to the cables I have on my Thorens:
Esoteric AVK3-3M Audio Video Kit 3m
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=189-380
Through a special buyout we are able to offer the AVK3 A/V kit to you for an unbelievable 50% off the retail price! The AVK3 kit will make your home theater connections simple and clean. Class II shielding and Accu-Image™ solid core conductors are use in the audio cables to faithfully deliver every detail of sound. Class III dual shielding and a True 75™ solid core conductor for the video cable recreates an exceptionally accurate image. Comes with 1 composite video cable and 1 analog audio cable. Limited quantities available. Available in 1M, 2M, 3M, and 5M lengths.
* 24K gold contacts
* Class II shielding on the audio cables
* Class III dual shielding on the video cable
* True 75™ solid core video conductor
* Split center pin
List Price: $64.98 EA
Your Price: $22.74 EA
These also caught my eye, for about the same money:
Esoteric EA2-2M RCA Audio Cable 2m
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=186-082
If music is important to you, then so should be the quality of the cables that you use to transfer the signal from the source to the amplifier. Esoteric's EA2 series of RCA cables offers great performance at a price that doesn't break the bank.
* 24k gold plated contacts
* Accu-Grain™ multi-strand OFC copper conductors
* Class I shielding
* Poly Flex™ outer jacket
* Phase Flow™ dielectric
Your Price: $19.98 EA
And then these guys, at twice the price:
Esoteric EA5-2M RCA Audio Cable 2m
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=186-124
Esoteric builds upon the EA2 series cable foundation with the EA5 series. Class II shielding prevents EMI and RFI from entering into the signal path. A Poly Flex™ outer jacket prevents cable damage while maintaining flexibility. The gold plated, dual-split center conductor connector prevents untimely disconnection and creates greater contact area.
* Phase Flow® Dielectric
* Ultra thick 24k gold plated contacts
* Ultra Sure Grip™ custom connectors
* Ultra Grain™ OFC center conductor
Your Price: $49.98 EA
Any thoughts on Esoteric Cables in general?
What about any of the specs on these three choices? Esp. on the first two--does one seem better than the other?
Finally, are there any flexible, gold-plated, copper-shielded in the $20 range for a 2-meter pair that might be better than these?
* 24K gold contacts
* Split center pin
* Class I shielding
