Thoughts on REK RAG101 Audio Signal Generator?
Appears to be a Chinese version of the good old Wein bridge audio generator, but with higher distortion specs than the better designs of olde. It's probably a good choice for speaker testing and general audio test bench duty, but not for accurate distortion measurements. I didn't see a spec for frequency response flatness, so it might not be good for precise flatness checks either.
Could one use Audacity and a USB DAC like the PS Audio Digital link III as a signal generator? Or will the opamps in the DAC create more distortion than a Wien bridge oscillator? Also, do all of the Wien bridge oscillators use a lamp to reduce distortion?
THD for the PS Audio DL III is 0.0005%. Can I assume a sine wave through it would be better than the distortion via a Rek RAG-101?
