Just my opinion, but the factory instructions detail a pretty poor method for adjusting bias. The fuses (which are not present in your unit) serve the complete AF section, and not just the output devices. As such, that method cannot be relied upon to indicate actual bias (idle) current separately from the rest of the circuit.
It would seem more appropriate to connect a millvolt meter across the emitter ends of R120 and R121 to monitor voltage drop through the total 0.66Ω stack, then calculate current. Given that the outputs are identical to those in a Pioneer SX-750, and those seem to work well with an idle current (bias) of around 30mA, it might be fair to presume that they would also be similarly happy at the same levels in the Luxman. Once the unit is up to operating temperature, a reasonable goal would be to attempt to maintain 20-25mV across the resistors, thus indicating 30-38mA idle current.
