Old1625
Has anyone here ever had dealings with bottom-end stereo phonographs--either portable or small console--that employ 3 output transformers? There are two smaller ones for "wing" or "satellite" speakers and one larger one that drives a center speaker of somewhat larger size.
The "wing" transformers--instead of having their red leads go directly to B+ instead draw through the blue and brown leads of the center "push pull" transformer, essentially making the output tubes serve as left and right "wing" channels for stereo, and delivering a "mono" push-pull signal to the center speaker.
I've personally never shaken hands with such a unit, as I had always gone for the big guns sporting 6L6s and 6550s back in the day. But the way I see it wired in schematics it would appear that one wing speaker would be out of phase with the other, (if the push-pull action is going to work correctly) inducing an annoying "wide" image. My instinct would be to reverse the leads on one wing speaker to correct this--which one depending on the phase relationship with the center speaker.
Has anyone encountered one of these gems?
