The 78 RPM unit is a "SICM" (Seeburg Industrial and Commercial Music) model in a wood case. These were used for background music in department stores and factories, hence the clock timer that would start and stop the mechanism at programmed times. The Seeburg amplifier is a nice monoblock with a pair of 6L6s and decent iron. The amps show up from time to time. It is interesting in that it holds 100 records (200 sides). You can see the trim piece in the middle of the carriage. The same mechanism was used with 50 records in the M100A coin-op jukebox (100 sides), and this has two 50-record racks on one carriage. 100 78s made it too wide for a jukebox, and 50 weren't enough for a decent variety of background music. This mechanism and the automotive-style 1950s styling pushed Seeburg above Wurlitzer in jukeboxes. Wurlitzer took a long time to catch up, as their mechanism could only handle 24 sides. The SICM mechanism was an elegant design, it would handle 10 and 12-inch records automatically. On the SICMs, each record had a lever to select side 1, 2 , both or skip. They would play continuously as programmed by the timer. Coin-op jukeboxes used solenoids to toggle a pair of pins for each record, controlled by a letter-number button matrix. As each record played, a solenoid on the carriage would cancel or reset the pin.
Seeburg later scaled the mech down for 7-inch 45s and it was essentially unchanged for well over 30 years of production. The 45-RPM equivalent to the SICM was called a "Library Unit". These show up from time to time and are fun to go through a box of random 45s from garage sales, etc. The cartridges were custom made for Seeburg by Pickering, and the later ones are quite good, considering. Early monaural cartridges had poor vertical compliance and will tear up stereo records. I have a 7-inch Library Unit that I retrofitted with a stereo pickup from a later model jukebox.
The home consoles were considered a high-end model at the time. The one shown is the later model with a keypad, earlier ones had a rotary telephone dial. Two digits for any of 100 album sides. These used toroid magnetic core memory to keep track of selections. A wired remote with a dial or keypad was available.
