Loss of signal vs what? Spades? Bare wire?
The most important thing about any speaker connection is the amount of surface area contact and how tight and air free that connection is between the joining surfaces. With a high quality banana plug or BFA type, I don't think you sacrifice much if at all versus a high quality spade from the likes of Kimber or WBT. The ones that prefer spades will argue that you get a tighter, more air free connection because you can torque down on the connection but I think a well designed banana plug provides a sufficient fit.
Also, not all banana plugs are made equally. Some cheaper banana plugs, I wouldn't go anywhere near them. If they slip in and out with hardly any effort, it's no good. If it's a choice between a cheaper banana versus a cheaper spade, I'll take spade each and every time. However, ones that are well made with a tight fit that gives an outward pressure once inserted are just as good as spades IMO. Ones like the Nordost Z Plug, Chord Company, Naim, and QED Airloc just as examples.
I'm not a big fan of banana plugs that look like the one below. The kind that have the flexible center shaft. The fit is oftentimes loose and uneven.
Some argue that bare wire is best because there's no other connection part getting in the way. IMO, bare wires are the second worst type of connection for several reasons:
1. The wires are directly exposed to oxidation.
2. The oils from our fingers touching the bare wire, increases the oxidation and corrosion rate as well as acting as a barrier to the electric signal, no matter how slight it may be.
3. Irregular contact surface.
4. Undue pressure or stress directly on the wire.
As for the worst type of connection? Spring clips, for the sole reason it gives the least amount of surface contact.
Knowing your self-confessed OCD with audio stuff, I'd like to know why you're not concerned with the loss of signal through use of the bananas.
