Citroen
2CV
So as not to derail the "If you have a turntable you should have a record clamp thread" http://www.audiokarma.org/forums/in...ntable-you-should-have-a-record-clamp.816837/
There are many reasons to use a record clamp.
1. To flatten a warped record
2. To couple the LP to the platter
3. To add mass to the platter (although this is more through a record weight rather than clamp, or could be through a heavy clamp)
4. Others?
The aim is MAINLY to improve sound quality, but sometimes just to reduce wear and tear on cartridge suspensions (through reduced warps).
I find that with a high mass platter, coupling the LP to the platter is beneficial.
However, with lightweight platters, or platters directly coupled to motors e.g through idler wheels SOMETIMES its better NOT to couple the LP to the platter.
On my Well Tempered Amadeus (light weight platter) no benefit from a clamp.
Garrard 401 great results with a Resomat, no clamp. In fact, no clamp with most mats on this TT.
A lot of variables. And a lot of differing opinions/controversy!
What are your thoughts?
4. Others?
