Retrovert
Addicted Member
I've tried Wet Look before, and didn't hear anything negative after. I mainly used it to help improve the appearance of some old, mildew stained woofers.
Members over at DIY Audio did some tests on woofers, before and after, using Wet Look. As far as they could tell, it didn't adversely affect performance. Most felt it stiffened the cone, improving transient response and bass detail. With the weight of the coating, it could slightly lower the resonance frequency of the woofers. But, that might not be a bad thing either. Heck, a lot of British speakers used to have doped paper cones, prior to polypropylene, I suppose. The cones must have been doped, due to someone in design, believing there was a benefit?
That is poor advice and it is based upon internet "facts" which have been debunked.
Problem: You won't hear a difference because acoustic memory is notoriously unreliable. Without an A/B comparison it is impossible to say what the effect was. That diyAudio discussion was, I believe, in the context of altering cone properties. Cone alteration is not something to be casually done to a vintage speaker.
Using PVA (aka white glue) would be disastrous, as has been well documented here and on Classic Speaker Pages. RoyC and others tested different sealants on AR-3 drivers, i.e. they actually did experiments, and aside from butylene rubber all of them ruined the surrounds and the speakers. Every. Single. One. Some hardened over a period of months, but harden they did and ruin the sound they did.
The PVA cult refuses to understand that hardening or stiffening a surround raises Fs, which ruins the speaker. It may also create or exacerbate a resonance problem. Gasket cement or diluted silicone are just as bad. This has been well documented with actual experiments, yet the dogma and internet lore simply will not die. People want to believe they can "fix" something when they don't understand the chemistry or materials involved.
I urge everyone to do research on this before applying anything to a surround. Once the surround (or cone) is modified it cannot be restored, it must be replaced.
Ken Kantor, who actual understands these things has many times explained the issues involved and how difficult it is to return a refoamed driver to its original functioning:
But, with a woofer, a careful job can get the driver functioning at least somewhat within the ballpark of the original. ...
However, with something like a midrange, the changes wrought by refoaming will be really extreme. There is almost zero chance of getting something close to the original performance, and the refoamer generally has no way to check was has been done.
How in the world do you folks know there weren't significant response changes from your midrange repairs? As a speaker manufacturer, I've seen tens of thousands of mids scrapped because a glue was applied at the wrong temperature or the cross section curvature of a surround roll was slightly off from print.
PVA (white glue) is not the material to use. It is stiff and rigid. Adding mass to the cone by painting it is a bad thing as the motor (voice coil and motor) was designed to move a specific mass, not the "improved" cone mass. This is not science, it is unsubstantiated opinion which has been debunked, over and over, yet people keep repeating dogma they read as if it were proven fact. When a cone is altered, (a) its mass increases and (b) its resonance properties change. This alters the sound. Speaker designers expend a lot of effort making cones lightweight for better and more linear frequency response. I don't know why aesthetics (does a shiny cone really look "better"?) encourages people to degrade the sound.
Actual science and testing has been done by Roy C to evaluate the effects of various surround dopants. Other than butylene rubber ALL of them, every single one, stiffened the surround and raised Fs. In short, other dopants ruined the speaker. Butylene rubber does not harden and thus does not stiffen the surround. (Think chewing gum which remains sticky for decades.) Roy's work remains definitive on the subject and he brought clarity which finally dispelled the audiophool miasma, although it keeps creeping back into town.
Here's a few of the discussions here about how PVA, gasket cement, etc. ruin the speakers.
http://audiokarma.org/forums/index....a-for-redoping-cloth-woofer-surrounds.608604/
http://audiokarma.org/forums/index.php?threads/speakers-fatigue-need-help.797689/page-2
http://audiokarma.org/forums/index....of-my-klh-17s-is-complete-long.102176/page-14
http://audiokarma.org/forums/index.php?threads/virgin-cloth-surrounds.637112/page-2
For the source material go to Classic Speaker Pages. Too much there to link. Google is your friend.
This is a long-settled and well-settled issue. The research is out there.
