OK y'all, that is bad advice.
The 240 in other countries is a hot and a neutral and a separate ground sometimes. The 240 here is balanced 120, which means you are putting a dangerous voltage on what is supposed to be the neutral.
And even if the danger doesn't get you, you are likely to get into hum problems.
Especially if this amp is to have TT to it, it should be run through a transformer.
Got two options here. One is to get the step up transformer. Another is to just get an isolation transformer for 240 volts. Actually these might be cheaper overseas, maybe. Service techs need to use them at times.
Or you could make a step up with two isolation transformers for the US. Just connect both of them in phase to the 120 and put the secondaries in series. Just remember the ampereage rating must be enough, and the VA. Buying two transformers might be more expensive than a step up.
I am not a licensed electrician but I know enough to be one. I learned from among the best. I have averted many catastrophes and this is one waiting to happen. It might not burn the house down, but there are so many different designs that you don't know what could be tolerant of impressing half the line voltage on the neutral, and is not.
I couldn't find much on this amp, how good is it ? Could you maybe sell it and pick up a high end Pioneer or something ? If it really has that special sound you like, I understand. If that is how it is, this CAN be done.
And actually, know what ? In the US there is alot of junk. We could go on a rampage looking for hefty transformers from amps that have gone all to smoke and add up the secondaries to make the voltage you need. Might be a bit awkward but might get done cheap. Put it this way, I got transformers from a JVC JR-S600 and a Sherwood AD-266R, I bet all the high current secondaries on them would add up to enough voltage. The important thing is that you can tie the neutral of the equipment to the neutral of the house wiring.
Do what you want, but simply running it off of US balanced 240 (works like a bridged power amp), if you get a problem with the power transformer in your amp, oh well. It might never happen but it might.
