Audiokarma. After replacing everything else on my Magnavox Micromatic, I attempted to replace the cartridge and wiring harness. The original harness had 2 metal-jacketed wires…brown and grey. The jackets were used for grounds. I ordered a new harness and cartridge from V-M. I used the green and black wires from the new harness as grounds. I grounded the metal cartridge bracket with one and the negative left pin with the other. I re-used the tiny metal hooped wire from the old cart onto the new cart. I believe it just bridges the negatives together. I used the red wire for the right channel and the white wire for the left. I ran the new wires to the same contact points near the RCAs as the original harness. I have NO sound now from the record player!! I can touch the RCAs and get a nice buzz. I can plug my blue tooth adapter into the record inputs and get great sound so I’m fairly sure the problem is somewhere between the cartridge and harness. I checked all of my new connections and then shrink wrapped them for protection. I did test all wires from the pins on the cart to the contacts on the RCA with my ohmmeter and everything checked out. Can someone please let me know what to try next? I’ve included pictures of the old cartridge and original RCA contacts as well as the new cartridge and new RCA contacts.
