Tone arm rewire question
kaplang
Works for me !
Is this a good wire choice for a Transcriptor fluid tone are rewire?
Description:
High quality copper Litz wire made up from 30 strands of 0.04mm enamelled copper wire encased in silk easy to work with.
3 metere is $4.00 comes from the UK
Does anybody know what .04mm converts to in Awg wire gauge?
Thanks
I've used the wire
Description:
Thanks
Pretty awesome...
That's about 46 AWG on the strands, 31 AWG equivalent. You can enter 31 in the calculator here for more info. You have to solder at a fairly high temperature to solder through the insulation- it's too fine to scrape it. It's important that all the strands get connected at each end. I assume the benefit is flexibility because that wire is actually optimized for a frequency higher than audio, though it should work fine.
