I have a Technics SL-1600. When the record ends and goes along the arm lift to return to the arm rest the tonearm bounces just as it starts to reach the arm rest. I tried turning the adjustment screw at the base of the arm lift counterclockwise and got it to turn a little. Turning it counter clockwise does help to a degree but the tone arm still bounces. I thought I read if the cartridge is too heavy it can cause the tonearm to bounce. The cartridge is an Audio-Technica. I dont know what model it is but its a budget model with a yellow body. Could this be a problem or is there an easy solution? Thank you for your comments
