My tube preamp SP14 has two toroid transformers in it. It has an IEC connector that joins chassis and earth grounds together. The build calls for attaching the purple shield wires to the chassis ground, but I have seen pics of the same kit build that connects the shield straight to the earth ground lug on the IEC connector. What would be the preferred way to wire the toroid, does it make a difference since both chassis and earth are connected internally in the IEC. Thanks.
