Okay, I have to admit that I don't like asking for help. But, I am far from perfect, I do not think I know everything, and I feel that I am humble enough to ask those far wiser than I. Which means all of you in AK Land.
So, I picked up the above mentioned unit, very nice, extremely well built receiver. I checked it out with DB Tester, looked good, fired it up, sounded good at first.
The right channel sounded like crap, hooked it to the scope and saw what I was hearing. Checked with headphones, sounded great in both channels. I unplugged the input from the pre-amp and jumped L to R and R to L, the right channel remained like crap. I know the problem is in the right channel on the main amplifier board PA-41B. I looked at the idle adjustment. The left side was at 9.2 mV (Spec is 10mB +/- 2mV), the right read 0? Huh? I thought perhaps dirty pot? I removed it and checked it, works perfectly. Put it back in and still read 0.
I pulled TR613 (2SD525) and TR615 (2SB595) and tested them, at first TR613 was reading as 2 diodes, I changed the leads on my Atlas DCA55 and it read fine. I thought I would swap the right and left pairs which I did. I did these one at a time, cleaned the old grease off the mica insulators and installed them. When I powered the unit up, both 5A fuses on the power supply board blew. I see nothing no reason why this happened, no solder bridges, nothing crossed? I checked the KBL02 bridge rectifier and it is good. Could it be the main cap (this uses a single cap with two caps inside)?
This does not make sense? All of the transistors checked good as I went about replacing them?
