Toshiba Sa-775 Bias / DC Offset
KrZ8
Hello,
I have a Toshiba Sa-775 75WPC with some dc on its outputs. There are several VRs on the power amp board but I cannot seem to find instructions on which ones to adjust, nor on where to check for bias. Does anybody knows ?
Thanks,
Alex
Thanks Darren!
It appears that this amp only has bias adjustments. Here is the relevant information for future reference and search purposes:
IDLING ADJUSTMENT
1. Connect a tester to test points No. 1 an 2, 3 and 4. (They are above the transistors)
2. Adjust the semi-fixed resistors (R535 and R536) so that the tester indicates 8.8mv to 22mv
Alex
It's only in the 30mv range, so there is really nothing to write home about just yet. It still sounds good. I just figured that I might as well adjust it while it is opened on the workbench.
I guess I'll just adjust the bias, clean the controls and put the cover back on for another couple years before changing componants :thmbsp:
thanks for your help!
Alex
