TubeJunkie
Master of None
Check again if you have low DC voltages at the coils L601 and L602
If your offset voltage is low try to adjust the bias. Can you adjust the bias close to the values on the schematic (16mV between the emitters of the oower transistors)?
If you have a low offset and the correct bias, it's about time to consider a possible fault in the protection circuit itself, because the protection circuit responds to three possible faults in the amp:
1- high offset voltage, detected by Q803 and Q805
2- high current in the emitter resistors, detected by Q801 and Q802
3- loss of AC voltage, detected by D802
You can confirm that the amp is running well if you have a good signal at the coils L601 and L602. I don't remember if you have a scope but if you don't have one, you can can touch the coil with the positive wire going to a (test) speaker, and the negative wire from the speaker connected to the negative speaker terminal at the back of the receiver (which are grounded all the time anyway)
Hi ecluser,
Low voltages at the coils L601 and L602, around 2.vdc. I now have NO voltage at the idle test points. I did the speaker wire to the coils test, and I had static / noise, So I feel you are correct in your statements, that the problem lies in the protection circuit. I'll check the resistors around Q801 & Q802, & surrounding area. Any other suggestions are greatly appreciated. I feel so close to hearing this baby sing. Thank You Again,
TubeJunkie
