Toshiba SR-410 turntable service/owner manual
Dust.Grim
Hi,
I'm trying to track down a service or owner manual for my Toshiba (Aurex) SR-410 turntable.
Any information would be appreciated whether it be screen shots or pdf.
Happy New Year,
Dustin
Yes, it seems the only difference is that the 410 doesn't have those stupid "fast - normal - slow" indicator lights that are completely useless anyway.
I posted up the service manual and schematic on VE for the SR-410. Can anyone tell me where the 9 pin socket contact is located on the TT, mentioned on page 14, step 4?
I've looked around and found nothing that looks like a 9 pin socket. I've had multiple symptoms since starting work on this one and the faults have been intermittent. It worked great to start after a full recap, then too fast for forward revolution, backwards revolution on startup and now no revolution. Any help would be greatly appreciated.
Did you solve the problem?
Backwards revolution definitely should be a faulty motor phase shift capacitor(s).
I did not get back to it yet. This summer has been a busy one. Surprisingly the SR-510C schematic is almost identical in the areas that count so I have discovered the area where the wave forms go wrong. TR608 emitter wave form is wrong but the transistor tests good. I'm thinking TR609 may be the problem. I have a replacement but I haven't got around to swapping it out yet. All the electrolytic capacitors have been replaced. I should be able to get back to it soon.
I am pending to repair a SR-510 (non-C, 100V Aurex version) that was mistakenly connected to 220V power.
I'll try to keep you informed here if I find some info of value.
I tried going to vinyl engine to download the SR 410 manual but they are no longer accepting new members. Can anyone help me get the manual? Thank you.
