Gnesen
Instead of cluttering up Poultrygeist's excellent TPA3116/8 thread, I figured there is a need for a new thread dedicated to TPA325x-based amps. As you may know, there are a lot of cheap ones now available from Yuan-Jing and other vendors on Amazon and eBay, both as completed units and as boards requiring some DIY. Please share your experiences with TPA3251/3/5 amps here, with the rationale being that early adopters are really beta testers who often get mixed results from new products. Of course, I realize there are other 'new' chipsets that deserve respect and attention too.
I'll go first: I now have two amps based on the TPA3255, one being the bare amp directly from Texas Instruments (TPA3255EVM) and the other being a cheap generic from eBay. While I haven't tried all the different TPA311x amps available on the market (including Allo's), my experience is that the TPA3255s just flatly sound better -- more power, less noise, and a nice even response from bottom to top.
A few quick details on the cheap one I got from eBay (mine cost quite bit less than currently listed):
- It doesn't come with a power supply or any documentation. There isn't even a model number listed anywhere on the unit, save for a simple sticker on the side.
- TPA3255 chips are supposed be able to handle 48V, as indicated in the listing, but I found that this unit gets quite hot at 48V even when not playing any music. After switching to a 36V 4A power supply, I don't feel any heat coming from the case at all. I strongly suggest using something lower than 48V if you get this amp.
- The Bluetooth works well, but the amp sounds better via the line-in (nothing surprising here).
- The amp is dead quiet. I don't hear any hiss or other noise at all coming from the speakers at any volume setting (with no input, of course). Nice!
- While there isn't an indication of the builder, I suspect the unit comes from Yuan-Jing, as when connecting to Bluetooth it identifies as "YJHiFi".
