Bert Beukema
Well-Known Member
Hi all,
I restored a Denon PMA701 that was completely butchered. It took me over a year as a side project but it is finally nearing the end. There is one thing that is bothering me though: transformer humming over speakers (noise).
One of the things that was butchered in this dual mono amplifier was the tertiary transformer feeding the pre-amp, protection and lamp. It was a tiny transformer and it was gone. I've implemented 2 transformers (one for the pre-amp at 24v) and another for the rest (at 6v). The 24v transformer is an isolated transformer in an epoxy case in the position of the original transformer. This is close to the power switch. I've secured it off the frame with pole brackets.
Thing is, it is generating an audible humming noise over the speakers. If I move the transformer out of the enclosure of the case the humming stops. It is a new transformer. I believe this might have something to do with being in close vicinity to the power switch (and powerline). That being sad, I don't really know what to do about it.
Tried my test transformer which is not isolated and it hummed three times as hard. Tried a metal shield between the transformer and power switch innard, no effect. The only thing that actually helps is moving the transformer out of the case.
Anyone have any ideas or should I just accept this?
Regards,
Bert
Regards,
Bert
