Blue Shadow
Waiting for Vintage Gear from this century
The Luxman L-580 has a couple transistors on each channel of the amp board, 2SB648 and 2SD668 on one channel in my unit and 2SB649 and 2SD668 on the other channel. Odd but what the heck that is what is in the unit and it worked for 20+ years. I did buy it used so maybe...
The amp board of this unit is mounted with the foil side up. This puts the transistor sticking down and the heat they produce rising directly up to the board. That board is now fairly well darkened.
I want to relocate these transistors to the top of the board and would like to heat sink them some what. I think a brace goes across the board that would need to be cut (an opening for the transistors to fit through) and maybe I can even use this brace as a heat sink.
The transistors are TO-126 so I would need some proper micas, plastic hardware...maybe, this might melt and possibly some extension to the legs of the transistors.
Any issues seen if I:
1) observe correct mounting of the transistors when moving them.
2) use wire to reach up to the transistor legs from the board mounting location
3) mount the transistors on the brace, properly insulated from that brace with mica and non-conductive hardware using a properly small amount of heat sink compound.
4) since these did not have heat sinks, will mounting them to a piece of sheet metal chassis brace and not something more like a heat sink be enough or should TO-126 heat sinks be used?
Since the amp was working for years with the 648/668 and 648/649 pairs is there any reason to hunt down a replacement for these transistors (649 specifically but probably should do all 4 if any are changed).
