kjello
Is it possible to post a PDF file?
Transistors mounted without heatsinks must dissipate heat through their leads, so shorter is better in that respect, but they're more likely to get damaged by soldering heat. Pick your poison.
The black band doesn't signify resistance value. It's meaning might not be standardized at all, but there's bound to be someone here who knows more on that topic.
Longer leads would have more heat dissipating surface area
Sorry about the delay. I finally join the hifiengine and got the schematic.Link to schematic: https://www.hifiengine.com/manual_library/nad/218-thx.shtml
So far I found:
Q326(C3788), Q318(A1478) shorted
Q338(D1975), Q342(D1975), Q344(B1317) shorted
Q332((A1837) shorted
R358, R360, R366, R368, R374, R376, R382, R384 all 4R7F reading mega ohms out of circuit.
R370 3W 0,22 ohm cement resistor reading mega ohms out of circuit
All this in the right channel power amplifier board
According to previous owner, damage probably caused by shorted speaker output.
Because it's normally assumed that PCB tracks are the primary means of heat dissipation. This isn't true in all cases, of course, but you will see this assumption commonly used in device datasheets.If the component uses the leads to dissipate heat, why would shorter be better? Longer leads would have more heat dissipating surface area
What you have is a severe blow out of the amp where you burned a lot of power transistor. It is normal for those 4.7ohm resistor to blow to protect from fire. You should use back the 1/4W 4.7ohm, DON'T change to 1/2W. This is serve as fuse.
I am not familiar with the black bend fusible resistors, I'll let other's that have experience to tell you what to buy. The important thing is to put back the same type resistors.
Did you change Q340 even it is not blown? If you bought these transistors in one batch, I would change Q340. Q340 has to match with Q344. If you bought one extra, replace Q340.
BUT if you don't have an extra from the batch buy, don't worry about it. This is because chances when you order a few at one time, those transistor are from the same production lot and have better matching. If you order again, it might be from a different lot and won't match, then you might as well take a chance on the original transistor already in the circuit.
I use these resistors ( not the same value ) for my amp:http://www.mouser.com/ProductDetail/KOA-Speer/MOSX3CT631RR22J/?qs=OpdMUBmMlYYxauT324hoog==Thank you for your answers
I have bought all 4 (driver?) transistors new Sanyo C3788 and A1478 that would be Q318, Q320, Q326, Q328
Also bought 5 sets of power transistors to replace the BJT D1975 + B1317 (discontinued) Replacements are Matsushita 2SD1718 and 2SB1163
Should I replace all 8? They seem to be arranged in a 4+4 configuration ?
The Q332 I guess is a voltage regulator ?
Resistors on their way 4,7 ohm 1/4 watts
As for the two "legged" emitter/cement resistor 3W 0,22 ohm I have not found yet...
I have decided to mount heatsinks on the pcb mounted transistors, I have 2 more of these amps that show the same traces of heat damage,
even though those other 2 amps are not hard driven.
On a sidenote
Also going to replace speaker protection relays.
These relays when old/worn, affects sound quality.
Again thanks for taking the time to answer.
Best regards
KO
Just referring to the pcb raised component mounting: look up 'xuron' lead forming pliers to bend the leads in a scissor shape that give the component a sturdier mount. Can use on said ic's, diodes and resistors in pic #1 offers better cooling (and the Ic's have been replaced in that pic as factory would mount them bout a half inch max. If voltage regulators i.e. in a ps circuit that appear hot you can glue on scrap aluminum to act as a heat sink.
I suggest the pliers because it also offers a 'stop' against the pcb when mounting thru holes. Then bend solder and cut. or if good? insert and bend and cut then solder![]()
I love them, I think they are much underrated,BTW, this looks to be a good amp. It is Current feedback frontend, 3EF( tripled emitter follower) output stage and 4 pairs of output transistor. Looks to be a much better than average amp.
I don't look at the name, I look at the circuit, it has the hallmark of a high quality low distortion amp.I love them, I think they are much underrated,
I understand. It is reflected in the sound quality I thinkI don't look at the name, I look at the circuit, it has the hallmark of a high quality low distortion amp.
