Tri-amping speaker advice
bobdod
I've decided that I'd like to give active tri-amping a go. I've got a vintage active crossover that takes input from a preamp and can divide the signal three ways, with output to thee separate amps to drive three separate drivers for low, mid, and high frequency.
I am looking for some advice regarding what speakers to look for. I know there were some OEM tri-ampable speakers from Sony in the 60's, but I've not seen any come up for sale in years. Are there any other speakers that are tri-ampable from the factory and can actually be found?
Alternatively, can anyone recommend a 3-way speaker that would respond well to tri-amping after I remove the passive Xovers?
Any 3 way JBL's with the 2 separate metal X-over boxes mounted in back can be tri-amped. as well as some older pioneer speakers.
But really its simple to make any 3 way speaker tri-amp capable . Your just by eliminating the internal xover.
then installing 2 new pairs of binding posts for the speakers
and have at it!
Yeah, I am very likely going to have to go the route of removing crossovers on something, as I've not seen anything that is set up for this from the factory. At least not anything responsibly priced. I'd love to find something like Sony ss-3300
Whatever route you go do yourself a favor and buy a measurement mic. Using a free software like REW you can measure the loudspeakers before you disable the passive network completely to get an idea as to how the drivers were optimized/integrated from the factory. This will give you some sort of baseline to follow or work around.
The mic will be indispensable when you start working with the active unit.
DIY open baffles
This is actually an interesting option as my other hobby is woodworking. I've never dabbled in speaker building though, as I don't know enough about design and component selection. Is there a known design or plans that can be found for this type of project?
